-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Please help me and take a good pic (http://forums.pelicanparts.com/showthread.php?t=146913)
Smile 02-03-2004 01:37 AM
of the 924 Turbo plate, located on the intake. (See picture below)
I need a GOOD quality pic, taken exactly from above, with the plate over the whole picture field. Would be great if you have optical zoom.
I will try to create such plate.
The original plate cant be ordered any longer from Porsche!
THANX a LOT!
http://forums.pelicanparts.com/uploa...1075801023.jpg
MixMasterK 02-03-2004 09:46 AM
Why not do a rubbing and scan it in? Or do you not have a decent one to do a rub on?
Smile 02-03-2004 11:13 PM
Correct. I have a blank space, where the plate should go!
Smile 02-04-2004 01:29 AM
Somebody must have this plate and a digital camera, or?
SoCal Driver 02-04-2004 09:57 AM
Try www.924.org
Also measure the opening including the radius at the corners and post it here for me.
Smile 02-04-2004 11:10 PM
The radius, I dont know. I would guess ~5mm. The opening is
~165 x 20 mm. I already have a stainless steel plate in this dimension.
I have already searched for pics on several web pages, including the one you mentioned.
I really dont understand why it should be such problem for some one to take a pic of this plate.
OK, many may have lost theirs, but some one should still have it.
SoCal Driver 02-05-2004 08:33 AM
The "problem" is that few here have a 931 turbo. Better luck at the forum on the 924.org site.
Thanks for the measurements. I now need to know what the length of the flat sides are before the radius. I can figure the radius them.
Why?
Well I may be able to load the graphic into Paint Shop Pro, tweak it flat, load that into Acad, do a 2D then derive machining instructions. Could do a 3D but I'll see how the 2D comes out.
SoCal Driver 02-05-2004 10:30 AM
Here is a raster image of the Acad file I just whipped up.
The Acad file is a vector file. Accurate to 20 decimal places.
A good photo would certainly clean this up to the point of being machineable.
http://forums.pelicanparts.com/uploa...1076005812.jpg
SoCal Driver 02-05-2004 02:37 PM
Here are some more from the covers of the factory 924 turbo manuals.
http://forums.pelicanparts.com/uploa...1076020591.jpg
And here is one of the opening pages. This just might be what your engine looks like.
http://forums.pelicanparts.com/uploa...1076020665.jpg
SoCal Driver 02-05-2004 05:02 PM
Here is the latest Acad file. Traced one of the better graphics I just posted.
http://forums.pelicanparts.com/uploa...1076029314.jpg
Smile 02-05-2004 10:08 PM
Hey SoCal Driver,
Ohnestly!
This was very nice.
I think the last one is what I want.
When ready ,I'll post a pic!
Again. THANK YOU!!!
Smile 02-05-2004 10:11 PM
Why?
I need to check this tonight!
I'll be back! :p
SoCal Driver 02-06-2004 07:35 AM
Hey SoCal Driver,
Ohnestly!
This was very nice.
Again. THANK YOU!!!
Let me know the falt side measurements between the radii and I can figure them out.
If you want a machine shop to mill you a name plate then I need to know what type of file they will need.
I needed the Acad practise. Been a while since I threw lines.
Tishabet 02-06-2004 07:43 AM
That was really generous of you, SoCal. Big thumbs up from me!
SoCal Driver 02-06-2004 07:50 AM
This out of work thing sucks. Have to keep myself busy.
I've been "doing" Acad since 1987. Still need to install my speed up menus and lisp routines into Acad 2002. I hate the stock menus.
Smile 02-07-2004 09:58 AM
Its 15.3mm between the radius, long side and 13mm between them on the short side.
Hey, but only do this if you are bored. I'm quite satisfied with the pics you made.
I have Pro/Engineer at work, but its hard to do something. But maybe I can try to import your pics as a kind of layer.
Anyway, Thanks once again.
Hope I can make this up to you sometime!
SoCal Driver 02-07-2004 02:11 PM
I'll feed that back into the drawing; 13 mm x 153 mm.
I'll send you a PM when I have it.
SoCal Driver 02-08-2004 11:08 AM
Now, now. Don't get this nice guy stuff going! Would ruin the dastardly rep I've been cultivating.
Also have an Acad file of a hood emblem that I outlined. Passed it on to a RennLister to cut some steel sheet metal from.
I'm working on some 1930's wood sailplanes. Converting 3 views to buildable scale RC. Keeps me busy.
