Hi there!
I'm going to do some g-tech pro tests with my 1986 951. The car has forged alloy Fuchs, full interior, the fuel tank is ¼ full and it has a LSD transmission. What is the weight excluding the driver? Thanks ALOT! Yan |
if you look in your manual, it lists the weight of an '86 951 as 2799 lbs.
Including the fuel, what would be the estimated weight?
Gasoline weighs 6lb per gallon.
Well I had my corner balanced the other day and I came in at 3190lbs.
That is with a 190lb driver 3000lbs But I have fiberglass seats, and no back seat and 1/2 a tank of gas, so if I had to guess I would put the car in at 3050lbs or so. Hope that helps. |
