Porsche Crest 944S Throttle Removal
Need to adjust / replace the Throttle Position Sensor, but the throttle body on the S appears to be impossible to remove without pulling the fuel rail and intake manifold. Is there a simpler way??? Thanks.
Old 03-09-2004, 04:58 AM
SoCal Driver's Avatar
Had some luck with two midgets and a mirror.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-09-2004, 06:11 AM
That probably would be easier. Now I need to find a couple midgets!
Old 03-09-2004, 07:51 AM
