Swapping tires?
I just picked up a set of 16x6/7's fuchs for my 911.
I'v been runing 15" phone dials with 195/65 front and 215/60 rear Dunlops on the 911 that I'm considering using to replace the junk phone dials and tires on the 944. Do you think I'll have problems with the 944's handling if I make the swap?
A J Burns '07 Guards Red Carerra 4S 911 Coupe w/Aerokit '86 Iris Blue Carerra 911 Coupe (given to my son) '63 Morgan Tiger Cub w/original Atomic 4 |
would you be willing to sell you "junk" phone dials for cheap?
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses www.apartabove.com |
Problem is that the 944 is nearly 50/50 weight distribution while the 911 is about 60% tail heavy. The skinny, tall 196/65 tires on the front of a 944 will cause some noticable understeer and steering mush due to sidewall flex. You'll degrade the 944's strength; great handling. I'm not sure about the safety factor of this tire combination, though.
-Dave- 1969 911/3.0l SC |
Yep, I'm a little worried about the safety issue. TNT25169, I'll pm you once the new wheels get in and I see what I'm doing.
