Here the heck is the DME??
I don't even know where the DME is. I was told it's under the passenger seat. I don't see anything under there. :confused: :confused: :confused:
hmmm on early 944s, it is under the driver's dash... maybe it is the same on the 924S?
Damn, you lot are quick. A bit more searching reveals you're probably right.
Earlies understeering column to the left..
Late under dash passenger behind a high tech piece of wood? Methinks. |
Yep, look directly under the steering column underneath the dash - silver box that says "Motronic" on it - that's it.
yeah but check your crank sensors before you change out the DME - Vertex has rebuilts for $389.
| All times are GMT -8. The time now is 07:29 AM. |
