-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   3 questions (http://forums.pelicanparts.com/showthread.php?t=157678)
GHEN 04-09-2004 09:33 AM
3 questions
Hello everyone,
Thinking of doing some things to my '87 NA.
As I was peeling back the carpeting in the hatch area, I came across a square (approximately 5" X 5") of a white synthetic type padding which, when peeled back revealed some electrical connectors and/or switches.
Question 1: What is that which I have exposed? I am assuming it is related to the fuel tank, but have no idea beyond that.
Question 2: I am thinking of eliminating the rear seats on the car and doing something else with the space. Has anyone taken the rears out, how much is involved, and what have you done with the space?
Questioin 3: What is the easiest way to get my lock codes for my keys? The 1 key I have with the car know is too far worn to copy, and I need to cut from the code.
Thanks in advance.
GHEN
Tishabet 04-09-2004 10:03 AM
1) that would be your sending unit for fuel level...in other words, the gas gauge gets its input from those wires.
2) lots of people take them out, it's fairly easy, many have replaced the seats with a speaker box.
3)with a copy of your title and the VIN from your car you can get a new key from a Porsche dealer...it'll be pretty steep though.
SoCal Driver 04-09-2004 11:45 AM
Fuel level sending unit should have a hard plastic cover over it.
Not much room under the rear seats for much of anything. Just deduct the three inch thinkness of the seat padding to get the idea.
Cost me $30 for a key via vin.
Tishabet 04-09-2004 12:34 PM
Mine definitely has a cover with a piece of white insulation on it, maybe they added this only to later cars?
As for the key, that's a lot cheaper than I would have assumed. Did that include the cost of the key blank and everything?
GHEN 04-09-2004 02:39 PM
I get a slight discount from my local Porsche dealer & mine came to $27.00 total (key blank, cut from my vin #).
I appreciate the advice.
If anyone has any pictures of a 944 with the rear seats removed, I would appreciate you posting them.
Thanks,
GHEN
Porsche-O-Phile 04-09-2004 03:02 PM
yep, 1 is the fuel sending unit - 3 wires (one is ground, one is the idiot light, and one is the level signal) / 2 is yes, it's easy to do if you want / 3 is off the VIN - exactly what everyone else said.
Welcome to the club!
GHEN 04-09-2004 03:58 PM
Appreciate all of the help, is there a step by step to getting out the back seats?
gtroth 04-09-2004 05:58 PM
Question 2 - somebody said recently that the 968 cab storage units fit 944s (can't confirm that, though).
