Acting up again.....
I tracked down an hesitation, then not starting problem to a loose reference sensor at the back of the engine. Now all excited that I drive again, I have a new problem. Well at least and intermittent problem. When starting off in from a stand still, nothing aggressive, the car hesitates and bucks as if I were a 16-year old girl learning stick for the first time. 2nd, 3rd, 4th and 5th are fine. I did notice that the "!" light is not fully on, but has a slight glow when starting off, but goes off after I shift to 2nd and so on. This problem only lasted about 2-minutes in stop and go traffic. But I have learned that no problems fix themselves.
Any ideas???
'08 BMW e90 335i 6MT stock [aka 'take two'] '12 Dodge Durango [family hauler] '86 951 (K&N Cone, Welt Chips, Tial, Zeitronix, P&P O-ring PH Head, WFHG, AFPR) [in storage] |
Could be alot of reasons for "bucking".
Number 1 Check the clutch, the rubber is probably breaking away Number 2 Check the voltage output of the alternator and clean all grounding points Number 3 Check the motor mounts (if cannot slide hand between the oilpan and crossmember replace) Number 4 Oh, did I mention check the clutch. Remove the starter and see if any chunks floating around Rick
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
but what would account for the idiot light to glow in 1st, then turn off after that?
Does it also glow when idleing? Lights on? radio blasting? Do you notice a difference with no electrical appliances running?
If yes to any of these indicates a voltage loss either from the alternator or bad grounds.
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) Last edited by FLA944; 04-27-2004 at 10:13 AM.. |
Radio definatly not blasting (I have surround sound turbo). Lights on, yes. I do not recall it changing brightness when idol. I will check.
I am wondering that the hesitation might have been a hickup in my fuel line.
