Power Mirror help
I removed the side view mirrors as well as everything else on my 1987 944 na. To remove them you have to disassembe the plugs on the door harness side. Silly ( stupid) me I forgot to make a digraham because it looked like they matched wire for wire...but not so..keep blowing fuses.
..does anyone have a digraham for the connector to the mirror assm from the door harness, or a pic of the right and left connectors on he doors showing the wiring. Any help is appreciated, Thank you.:confused: |
Can you pop out the switch assm from the outside?
I'll take a picture for you if you give me some pointers. |
I have the mirror motors off the car, when you remove the base you have to disassemble the connector on the door to get the mirror base off.
You would need to remove the mirror glass and then unbolt the 3 8mm from the motor housing to expose the wiring. |
| All times are GMT -8. The time now is 06:33 AM. |
