Vented nose hole size?
I want to make a template on the computer to cut out my front panel.
Does anyone have the dimensions of these?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
I've got a spare sitting in my garage. I'll try to remember to measure it tonight and post.
Thanks Buddy....How do you end up with a spare one of those?
Got 924? I will make the template and post it here as a photo if you can get the specs.
Bought it off ebay a couple years ago. Can't decide if I want to install it or not.
That looks very nice on there.
I like the blue also... Do ya know the name of that color blue ???? How are you gonna cut and finish the panel ???
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat |
The holes are 6 1/2" x 2 1/2" with a 1/2" spacing between each one. I can email you pics if you want.
Thanks for the measurements!!
I am not sure how I will cut/finish the thing...going to "draw" them on with a china marker first to see if I like them....... Don, that car is probably the finest example of a modded early I have ever seen. Can't remember the guys site (from the netherlands)
That's mmmbeer's car. I don't even know if it should be called a 944 anymore, something like a 948 (944 + 968motor and running gear plus turbo). It sure is nice!
Here are some more dimensions for you as well, that I took from my old vented panel before I got rid of it. http://forums.rennlist.com/rennforums/showthread.php?s=&threadid=125582
1985.5 944 Club Sport My P-caronline Profile "A good time to keep your mouth shut is when you're in deep water. "-- Sidney Goff Last edited by tifosiman; 05-04-2004 at 10:03 AM.. |
Thanks Tifo - I am still struggling with photoshop on this one... wont be long though.
That 964? is a real 'spared no expense' type of look. Too bad I'm on a budget.
Here is the accurate - i believe - template for the nose vents.
Copy the pic then blow it up to 150x origional. You should have 2 of the nose vents then. Anyone ever done the vents at half the height...sorta like the 911's?
Update,
Printed out an accurate set and a smaller set, fit 5 holes in the smaller set instead of 4. I am going to cut the templates out and post a pic tommorow. Any idea the best way to cut these things out?
Burn the fire.
Use a small cutoff wheel (pnumatic, if you have an air compressor) or use a tiny cutoff wheel on your dremmel. It's probably going to take a lot of work to get those done right.
Or you can take the front nose panel off, mark and use a drill press to start your holes, followed by using a scroll saw. If/when i do mine on my 924, i'll probably take the nosepiece off and use a mill. But then again, i have access to a mill...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
