Modded 931 intake
Thought some of you might enjoy this;
Old 05-17-2004, 12:28 AM
Burn the fire.
Brando's Avatar
Shawing!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-17-2004, 01:27 AM
what's the valve cover off of a Model T?
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 05-17-2004, 05:19 AM
Thanx Brando!
Ferrara.
Yeah.Something like that.
Prob with this model T is that itīll pass you hardcore in the fast lane.
Old 05-19-2004, 09:43 AM
jm951's Avatar
Have you done any dyno testing on it yet? Looks like it's hooked to an intercooler as well.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 05-19-2004, 09:53 AM
Burn the fire.
Brando's Avatar
Hey Racing... Not to criticize too terribly... but is there any chance you could have done a prettier welding job on that aluminum? I know TIG is hard (tried and failed about 30 times) but seriously, drop that thing on a mill and clean it up.
Old 05-19-2004, 02:15 PM
I hear ya Brando.
What you see is NOT tungsten inert.
Itīs a kind of solder called alutite.
Didnīt work for crap..so...it IS now TIG welded instead.
Yeah.I run a built to fit front mount cooler.
..as well as a hybrid K26/K27 huffer.
Sports a 50mm inlet for the compressor on a 78mm wheel and 160mm housing.
Limit boost to 1,7 bar.
Nope.
Havenīt been on a dyno yet.
Still street tuning via a wideband LSU4 and pyro.
Starting to get there tho.
Old 05-20-2004, 08:49 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Racing....
What car did you pull that intercooler out of ?
DOes it fit right in the front of the rad ?
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-20-2004, 09:02 AM
Burn the fire.
Brando's Avatar
-> Racing, Glad to hear it. I've never tried Alutite. I've heard of it, but never ever tried it.
That radiator probably alleviates all cooling probs,
Old 05-20-2004, 03:46 PM
ae.
The cooler isnīt off of anything.
Itīs a race element that we cut to fit in front of the rad and made our own tanks for.
In other words made to fit.
Brando.
Yes,the cooler works wonders.
At 1,7 bar weīre reaching outlet temp sneaking up on 160-170 deg celsius with current exhaust.
Into the TB weīre still at 35-36 deg celsius.
(To convert to F itīs +32 divide by 5 and mulitply by 9 if memory serves me)
Iīve used alutite numerous times before to make brackets of all sorts aso.
The thing with it is that it usualy leaves a MUCH more beutiful joint.
Dunno what F,ed up when i made the intake first time out,but F up it did.
After just a few bursts with full boost i started getting hairline cracks at the rear of the plenum.
When we took the TIG to it we almost gave up at one point,cause the alutite made it almost impossible to weld.
Did tho and the end result is all good.
Old 05-21-2004, 02:02 AM
