ilikemy944's Avatar
Send a message via AIM to ilikemy944
Talking Update for Wolf and Alex
OK.
Get rid of cyclic valve.
Got the other thing installed (MBC).
Now, first, almost 12psi drops to 11 at far end of revs.
2nd, 14 psi, drops to about 12.
3rd, 15 psi, drops to 14 at 5000 rpm (I pussed out, damn speed limits).
Now, the interesting part...
4th gear... I get 16psi. Which is scary, so I'll stay out of it, the MBC is adjusted to full MINIMUM. Hmm...
The more interesting part... In 5th gear, I am at 15 PSI!!! BEFORE! 3000 rpm!!!
So, I'm happy with it for now, until I blow it up anyway :P
Still idles high when hot, but runs better
I had a broken line at the cyclic valve.
Anyway I'm on the way to the Tail of the Dragon to see SR944!!! cya :P
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 05-21-2004, 06:40 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I am pretty sure I mentioned possible crack on that cyclic valve. hehehe
Your welcome Uni Nut.
Remember quality not quantity (inside joke)
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-21-2004, 08:05 PM
Wolf1's Avatar
Nice Brad!!!!
Did I mention that wastegate is shimmed...!!!...???
Sounds like its working good...
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 05-21-2004, 08:53 PM
ilikemy944's Avatar
I need to figure out something...
I get just over 16psi in fourth, and I get 17psi in 5th.
I can't go heavy throttle in fourth or fifth I'm scared I'm going to kill the head gasket. Sounds like its probably time for 3.0bar FPR and a A/F ratio gauge... :P
BTW - tail of the dragon = fun, with hiccups (more on this later :P)
Brad Tompkins
Old 05-23-2004, 07:19 AM
ae1969's Avatar
Uhmmm You dont want to be running those numbers for too long thats for sure....
Are you sure you adjust that MBC all the way down.... is it the lindsey one you bought ???
Old 05-23-2004, 09:12 PM
ilikemy944's Avatar
yeah its adjusted all the way down...
Yes its the lindsey one, but, it was sent to me in error :P
Brad Tompkins
Old 05-24-2004, 07:55 AM
