Sensor locations
Hey, i was just wondering where the following senders/sensors were located
Water temp Oil Pressure Fuel level If you had pics or diagrams, that would be great too. Thanks, Shawn |
Fuel level... Pull up the carpet in your trunk, see painted-padded plate with a black rubber plug (very large). Open that up, there's your fuel-level sending gauge :)
Water temp for the gauge and for the engine computer are seperate, they're both located towards the front of the engine, on the head, close to where the head meets the block (under intake manifold).
Oil pressure gauge sender is located roughly under the oil filter, obviously on the passanger side. Ahmet |
| All times are GMT -8. The time now is 03:10 AM. |
