i thought a weight reduction is always good ?!!?
¾ the parts gives you ¾ the weight :D
next :
windshield and wipers wheels radiator and fan rear glass hatch that C&C laser cutter was the best investment i made in a loooong time :D |
hahaha, C&C laser my engine block too :)
can do buddy,
take your pick : 1/4th of each cylliner, and respectably 1/4th of the surrounding block per cyllinder or the engine block , 1/4th of it , over the lengty of the engine or 1/4 of the bottom the possibilities are endles, it's up to you, what's your overal strategy with your car... :D |
i wonder if the laser C&C process can be used to enlarge the cylinder bore?
dunno ,
i know a place that has one of those puppies, fully automated, takes it's own chizzles and drills , whatever it needs just enter a lump of aluminium , and some specs, and the bugger delivers...it even figures out how to get the most parts out of the lump of aluminium for you... with a machine like that, i wouldn't need no stinking parts i just need specs...trouble is, it costs several millions and they aren't letting me play with it :( they waste it on stinking chopper engines then again, if they'de let me play with it i'de end up with a whole lotta useless parts and a broken machine, so i guess it's pretty wise of them :D |
Brando,
little off topic, do you know anything about conversions to either EFI or Webers on a 924 block? i know the Weber conversion has been done, but what's the result ? reliability and performance wise haven't seen any EFI conversions , do you know if they exist? |
Both have been done. Check out www.924.org.
it doesn't mention much results, do webers give more power or less?
are they easier when it comes to starting the engine in cold/hot conditions? i suspect EFI is kinda overkill and expensive for a 924 |
Think the 944 DME setup has been fitted to a 924. You could get a complete set up for less than $500 I would think. Have to figure out the fuel rail thing and the speed referenece sensors but seems to be do able.
You'd have to fabricate or find a flywheel speed reference sensor... Depending on what kind of DME you get, you might need to do some extra work with the flywheel. Early flywheels have 2 or 3 magnetic marks on them, late only have 1 (am i correct?).
If anything i'd suggest having your block bored out to about 2.4, get the big-bore pistons and rings, then carb the mofo. Looking at anywhere between the 150-165 horsepower range. You sacrifice fuel economy for more power all across the band. |
so carbs are more power?
what is there to expect on the stock 2liter? |
More low to medium range torque, depending on the setup. If i remember correctly, your power band is determined by the height (length) of the intake manifold, and height (length) of the velocity stacks... Get a good look at what's available on the market and see what their benefits are. If you want to retain fuel economy... keep to the CIS and associated headaches.
but fuel economy , if that's what i want, i might as well get me a friggin new car... :D
Going with carbs on yours will get you about 10-15 more HP, and that's a generous estimate. The intake will also sound throatier, and you'll be pulling in hot engine air instead of cool outside air like your CIS. So i'd also suggest fabricating up an airbox that directs cool air from outside to the carbs...
if the performance stays the same , or more ,then that's fine
is it more reliable ? cold / warm starts difficult to maintain? |
Reliable... I'd say in my experience of mechanical injection VS carburetion... Carbs win. Electronic fuel injection VS carbs... EFI wins.
Cold starts... you'll be keeping your foot on the gas pedal until it reaches operating temp :) Warm starts... no problem. Just imagine that you'd be driving a VW bug and have all of the carb issues associated with that. As long as you keep them clean, air filters clean and good fuel, you're good to go. |
sweet, me wants!!
now to find me a european supplier of the little sidedraft buggers. EFI , although cool sounding , is to much hastle, and it has chips. i don't like chips much.... to much of those at work... |
ok , lill update
apparently nobody in europe sells the conversion kit and i don't feel like forking over 200 bucks in shipping costs either so i got jiggy with the CIS instead turns out , that the CIS electrics were dead so i simplified things : 5th injector now has a wire going to my rear window defogger switch cold start = on hot start = off warm start = on highway = off red light = on speeding = on crude, but effective and still cheaper than spending 1500 bucks on a weber conversion :D |
| All times are GMT -8. The time now is 12:28 PM. |
