Brake Pads
Getting ready to install turbo brakes in my project, but need to get a set of pads. Anyone have suggestion on a decent set that will give better than stock performance, but won't make me grit my teeth at every stop and cover my wheels with a fine black powder? I'll be running drilled Zimmerman rotors as well. Thanks
Louie '85 (Early) 944 - Beater '87 924S - Crunch/Rebuild '76 924 - Long Gone "If everything seems under control, you're just not going fast enough." - Mario Andretti |
A set of cheap mintex pads should do just fine (under $30!), considering this is quite the brake upgrade. Unless you're doing something crazy to the engine too, it would not be a problem.
Ahmet
Cheers! |
Parrothead member
I have Ferodo's on mine now , but ive used Pagid and Mintex before. I'm really happy with the Ferodos
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I just installed a set of Hawk HPS pads last weekend. They are supposed to be good for street and "light" track and autocross. So far so good from what I can tell ...
87 944S Green/tan 250# springs, Koni yellows, front and rear sway bars, front strut tower brace, roll bar, five-point harness, SFR catback, Hawk pads, Kenwood/Alpine stereo |
Another vote for Ferodo street pads here. Good for street and auto-x.
