Blower stuff...
Ahum, good thing i took my blower out and opened it up. The big 'doors' that can close the fresh air intake via the vacuum system have completly rusted away. A couple of months more and the whole thing would just broken off:
Hoping to find some new ones and make that thing last another lifetime. Also, how can i get the motor itself out? It seems as if it is hold down by two straps, but i've tried several things to release them without any luck: And last, is this some sort of temprature sensor for the incoming air?? It seems like it, but are there any ways to check it's function etc (i've looked around the internet but could not find any specs of the pins etc): Thanks for any feedback |
I think that is the fan resister set, it and the fan switch together control fan speed. On the other stuff, beats me, I haven't had to get in there yet.
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
Yup those are the fan speed resistors....
The motor should pull off the housing..........may need alittle prying I have neverseen such badly rusted out flappers..........
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Got the blower out, and again: RUST. I don't know what the PO did with it, but it looks like he drove it into the ocean with the fans on full or something. How can a thing like a blower motor be so corroded.
hmm, think of these resistance's, as a pipe, with a valve. valve full open=max flow, valve half open=less flow, etc, etc. all the resistors do, is to vary the voltage, to produce different fan speeds.
1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten. |
Ah, and they placed them in the air stream to cool them down and keep a steady voltage?
Yes, they generate a goodly amount of heat.
