What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Ignition wire
I have good Beru connectors, but maybe bad wires.. Where can I get just the wires?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-26-2004, 08:14 PM
Granite 944's Avatar
I recently bought wires only from Kingsborne. They were red 7mm silicon wires with the M3 screw connectors crimped on. Cost $25.00 for the set. Heres a link....
Kingsborne Wireworks
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 06-26-2004, 11:13 PM
SoCal Driver's Avatar
7 mm OD insulator. 16 gage stranded wire. Most any decent parts store.
Drill out the threated section so you can solder the wire in. Make a U shaped notch in a piece of hard wood and use a large nail to stake the barrel of the connector into the insulation so it does not rotate when you screw the end of the wire back into the connectors.
What makes you think you need wires?
P.S. I'm in Temecula till late Tuesday. Bacchus Time!
Call me.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-27-2004, 08:16 AM
