-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Starting problems, wire boot corrosion (http://forums.pelicanparts.com/showthread.php?t=169609)
Gold83 06-26-2004 05:14 PM
Hello, I'm a new member but longtime reader of the forum.
My '83 944 w/ 95, 500 miles was operating perfectly, but on a humid day when I tried to start up it cranked but would not start. I went back to it later in the day, and it started but with a weird sparking sound. After starting it ran normally. Now it refuses to start in all but dry, warm conditions (weird).
Pulled wire caps: cylinder 1 perfect, 2 slight darkening of cap metal and plug cap, 3 gray ashy corrosive look, 4 light colored ashy corrosion. I have relatively knew wires and bosch platinum 4 plugs.
What's up? I suspect I just need new wires and plugs. Anyone know what's up here?
ALSO: I'm about to change the fuel filter and oxygen sensor. Is it as easy as it seems? I'm not very experienced working on cars.
Thanks a lot
AFJuvat 06-26-2004 06:04 PM
Definately get new plugs and wires - new cap and rotor will not hurt either.
Fuel filter and O2 sensor are not difficult - make sure the car is well supported when youare under there
o2 sensor - 22mm
Fuel filter 17 and 19 mm - you will need 2 19mm wrenches.
AFJuvat
Gold83 06-27-2004 07:57 AM
Thanks AFJuvat!
SoCal Driver 06-27-2004 08:13 AM
Don't forget to clamp the fuel lines.
Don't loose the stoffenduffus washer.
