-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   AC Recharge. Should I try this? (http://forums.pelicanparts.com/showthread.php?t=170209)
bertman 06-30-2004 09:32 AM
My 84 has begun to blow only cool AC, but not cold. The system is original R12 and has been serviced only once since new, in 1998 (replaced low side hose). Apparently there's now a very slow leak and I'd like to add some R12 to make it cold.
http://members.rennlist.com/cnalljr/mini-Im000272a.jpg
Is the arrow pointing to the correct valve for adding freon? Will EPA arrest me for trying this at home?
TIA
Porsche-O-Phile 06-30-2004 07:54 PM
Where the heck are you finding r12? Also, how do you plan on replacing the oil that you've no doubt lost along with the freon?
bertman 06-30-2004 08:37 PM
I've had a can of R-12 in my garage for years. I assume it's OK. Since I can't detect any leaks and the charge has essentially held since '98, I'm assuming that the leak is so small that no significant loss of oil has occurred. Could be wrong, tho.
Just trying to verify that I've identified the correct valve for recharge.
Moneyguy1 07-01-2004 12:30 AM
Bert:
Yes.
I wonder if they could have put in a more inaccessable place.....
Wait..Don't want to give them any ideas.....
