Is it as easy to strip the spark plug hole as my manual says? Becuase, when I did it I was on edge the whole time. Not only that, but it's hard to hand-tighten through the wee little areas between the air intake deal.
My plugs are a good deal tighter than anyone here seems to recommend. They haven't stripped yet, but I do make sure that I hit the correct threads before I torque them down.
great tips on how to change the plugs...
http://www.advanceautoparts.com/howtos_tips/index.html Check out the step by step instructions on the right side as well. Quick question: Which is the best/optimal spark plugs for the 944 n/a? And..... shouldnt we check the gap before installing? |
I hear alot about using "compressed air" to clean the plug area. What about all of us that don't have a shop compressor?
mebbe if we got some friends together and all blew at once... ...we could hyperventilate and get dizzy? |
GHEN |
Thanks.
I'm sure the aerosol in that would make you seriously dizzy, |
Aaron |
What? I'm going home to look at my can of it now.
We're talking about the $5 a bottle stuff, right? |
I use a shop vac with a straw-like tube duct-taped into the hose. And I vacuum out the debris (I don't blow it).
Ever notice that if you shake the can while spraying it gets insanely cold? Or that if you hold the can upside down the liquid comes out? It's a refrigerant. Aaron |
correct me if I'm wrong, but shouldnt you be very careful while cleaning the sockets, you dont want debris getting into the engine, so why the compressed air?
Aaron |
| All times are GMT -8. The time now is 02:41 PM. |
