will door fit?
Dose anyone know if a drivers door off of a 1987 924S will fit a 1987 944 NA? Are the doors set up the same? Thanks.
87 Guards Red 944-NA
Old 08-17-2004, 11:59 AM
SoCal Driver's Avatar
The door shell should be the same. Don't know about the extra brackets for the auto door locks. You will have to use the door panel (including the switches) and the rear view mirror off of the 944 IF the mirror on the 924S is like the early 944's. Different internal drive and motors.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-17-2004, 12:57 PM
