alternator not charging
My alternator doesn't seem to be charging. The car cranked over slow this morning and now won't start after a 15 minute drive to work.
Is the alternator externally regulated on an 87 944? |
check to see if the alternator lite comes on when you turn on the key, could be a bad bulb and that will keep the batt from charging.
internally and the vr can be replaced on mine, not sure on the later one's. |
Changed the reg, cleaned the terminals - all good.
| All times are GMT -8. The time now is 09:11 AM. |
