-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   How critical is this..... (http://forums.pelicanparts.com/showthread.php?t=179432)
ender944 08-25-2004 12:04 PM
I was just underneath my car about to lossen the allen for the coupler from the torque tube to the trany, when I marked the trany shaft it suddenly occured to me that this part was not going to be on the new trany so i would have no referance mark when putting the car back together with the new trany.....so how critical is it that the coupler is on the right spline of the new tranny shaft.....????
Nigel Haslock 08-25-2004 12:26 PM
I fail to see why it would make a difference. The coupler is balanced, the torque tube shaft is balanced and the clutch disk is balanced. There is nothing else on the torque tube side that can be aligned.
Nigel
jm951 08-25-2004 12:44 PM
It's not critical at all. Just make sure when you reinstall the new tranny to run the bolt back down and properly torque it.
ender944 08-25-2004 01:34 PM
Proper torque?? You must think I'm a CERTIFIED tech! :D Just kidding, Thanks for the help hopefully ill have it all done by Saturday night!!!!!!!
jm951 08-25-2004 01:35 PM
You don't have to be a certified tech to get torqued!!!! :D
ender944 08-26-2004 07:26 PM
I GOT THE OLD TRANNY OUT!!!!!!!!!
WOW......:D :eek:
qawse 08-26-2004 07:32 PM
someone ansewer my question now
944 Ecology 08-27-2004 08:48 AM
And what question would that be???
gb
ender944 08-28-2004 10:45 AM
Okay for some reason (cost?) the PO put two 5/16 grade 2 or 3 bolts to hold the trany to the tranny mount...of course the bent.....does any one know the proper part that is supposed to reside there, the dealer is closed and it doesnt seem like i can find a grade 5 or 8 bolt that long........I would really like to get this thing running tongiht...any help??
ender944 08-31-2004 09:41 PM
Thank god Porsche built tractors.....I went and got two grade 8 5/16 bolts that where 4.5in long from the Tractor Supply Company and mounted my tranny, it all worked out great except that the torques for the cvs kept stripping, im going to replace them with new allen head bolts here soon but its done i finished.....in the morning im going to take it around the block illeagaly of course, no plates no inssurance, but eh at least ill know if everything works!!!!
