-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   icu unit (http://forums.pelicanparts.com/showthread.php?t=192225)
bewerss 11-14-2004 08:55 AM
icu unit
is there any way of testing the icu unit as i have done some voltage tests at the coil and they seem wrong in that the voltage at terminal 1 is around 4 volts and the voltage at terminal 15 is 9.5 volts the haynes manual says that the icu unit is u/s if high volts at number 1 and battery u/s if low volts at 15 but it is a new battery
The car is a 1983 924
TCMdocs944 11-16-2004 03:33 PM
icu unit?
fast924S 11-16-2004 04:57 PM
idle control unit??????/ icu????/ need more info
AFJuvat 11-16-2004 06:41 PM
icu: Ignition control unit
Check terminal 4 of icu between it and ground - you should read battery voltage. Failing that, your coil or ballast resistors are faulty.
IF that all tests good, check voltage between terminal 1 of coil and ground (with ignition on) it should read 2.0 volts max.
If the voltage is incorrect, your icu is faulty.
AFJuvat
