scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Exclamation question on shredded ball joint and tie rod end boots
is it safe/ok to drive on tie rod ends and lower ball joints if the boots are shredded? even if they feel like they are in there very tight? what kind of damage could this cause?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 11-15-2004, 07:38 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Uhmmm you can drive that way.......
Those ball joints will be toast soon enough. Nothing like dirt in a nice smooth joint. Just check for play every once in a while.
? but you have the steel control arms on that 924S? those are cheap and easy to replace.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-15-2004, 07:43 PM
hehe i never said it was for my 924S....
i didnt specify because it would probably get moved and i wanted to know what you guys on THIS board had to say about it. but it could very well be for any car really.
Old 11-15-2004, 07:52 PM
s928s's Avatar
The boots are to protect the joints from dirt and keep the grease in. With the boots torn, it does not make it unsafe. It just allows then to go bad faster. dirt and debris will get in and wear at the joint and wash the grease out. There are replacement boots out there like at napa and pepboys and such, you may find some that fit.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 11-16-2004, 04:08 AM
