Cam Housing
I am trying to break the cam housing free from the head, I took off the 8mm and 6 mm bolts and the 10mm bolts on the back of the housing, I'm I forgetting something, or does it take a good whack with a rubber hammer to loosen the housing from the head gasket?
Frank in Naples, FL
1972 911T
1983 944
Old 11-15-2004, 07:06 PM
watch out for the lifters jumping out. I believe I had to tap a bit. Bolts out of the plastic timing belt cover? If I remember correctly that stumped me for 3 seconds.
If you don't live life on the edge, you take up too much space.
Old 11-15-2004, 07:18 PM
s928s's Avatar
Make sure you have all the bolts out across the lower outside and the the ones out under the cam cover plugs. there are 2 10mm behind the timing cover in the front, there is one 10 mm holding the cat. sample tube in the rear. If you have all of the the main allen head bolts out it should start to lift up because the spring tension the lifters are under. Make sure when you are removing the cover you sort of roll it to the right fender to catch the lifters..they will try to slip out. Try to keep them in their propper order.
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 11-16-2004, 03:56 AM
meister member
speedracing944's Avatar
do you have the cam belt off? i know its a stupid question.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 11-16-2004, 05:55 PM
