Low Low is offline
Low's Avatar
Question Stub axles
Well ive started the process of replacing the half shafts and bearings, and quite frankly have hit a wall . Hayes says to torque the castle nut down to 340 fl/lbs... well ive established that there must be a crush sleve. My question is does one have to replace these, or can you just put new bearings slide it back in. If so how much torque would it need? Any help would be greatly appreciated.
'84 944 All stock except the optional lead foot.
Old 02-11-2005, 03:34 PM
There isn't a crush sleeve, only a spacer. Make sure you assemble everything correctly. You will need the inner and outer seal and the outer o-ring. Tighten the hub nut to the correct torque as you posted.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-11-2005, 04:04 PM
Low Low is offline
Low's Avatar
...so there isnt ehh thats what i get for listening to a chevy mechanic. And yes i have all the seals i just wanted to make sure i had it right the first time. Thanx for the help.
Old 02-12-2005, 01:28 AM
When working on these cars you should have a workshop manual.
Old 02-12-2005, 08:46 AM
SoCal Driver's Avatar
Also the spacers have to go back onto the sub axles in a certain direction/order or it doesn't tighten correctly.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-12-2005, 11:48 AM
