livewirevoodoo's Avatar
Ignition Maintenance
plannning on replacing dist, rotor & wires in the coming month..
I see Pelican has 3 different wire sets available.. OEM, Magnecor and Clewett. Other than price, any discernable difference between them? Why would I choose one over the other? This is a stock 944, used as a daily driver.
Also, Pelican's catalogue lists 2 rotors - OEM and Bosch.. Same questions apply. Only difference I see is that for the Bosch the "shaft adaptor is NOT included". Would this justify the $70 difference in price?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 02-12-2005, 07:38 AM
We just use the OEM (Beru or Bosch) stock Bosch plugs, rotor arm without the shaft and the cars keep on going. Make sure you replace the fuel pump relay if it's more than five years old.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-12-2005, 08:51 AM
