Well ive started the process of replacing the half shafts and bearings, and quite frankly have hit a wall
. Hayes says to torque the castle nut down to 340 fl/lbs... well ive established that there must be a crush sleve. My question is does one have to replace these, or can you just put new bearings slide it back in. If so how much torque would it need? Any help would be greatly appreciated.
'84 944 All stock except the optional lead foot. |
There isn't a crush sleeve, only a spacer. Make sure you assemble everything correctly. You will need the inner and outer seal and the outer o-ring. Tighten the hub nut to the correct torque as you posted.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
...so there isnt ehh
thats what i get for listening to a chevy mechanic. And yes i have all the seals i just wanted to make sure i had it right the first time. Thanx for the help.
When working on these cars you should have a workshop manual.
Also the spacers have to go back onto the sub axles in a certain direction/order or it doesn't tighten correctly.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
