when i drift my 944 i use a few different methods depending on what im trying to do. The best way for me is to speed into the corner and trail brake than heal toe, let off the brake and throttle than turn into the corner hard hit the brakes than gas. You should be sideways at this point. The brake will move the wieght to your front wheels making the slide easier. I heal toe before turning because it allows me to slow the wheels a bit and do a slight shiftlock. I heal toe to 3200 rpm instead of 3500 which slows the wheels just enough not to lock them but instead move the weight and slow you down. Than you turn into the corner and brake for like a split second pretty hard this causes understear so when you let off the brake it will cause overstear. By letting off the brake and giving it no gas for a second it sets the car up perfectly to be turned sideways with a quick punch of the gas. imediatly after you hit the gas you should be sideways and counterstearing while slowly reapplying throttle to keep the car within its torque band so that the wheels stay spinning.
Also make sure you counterstear enough i used to just turn the wheel like almost once around and it wasnt enough. It took me a while to figure this out. I turn it almost two times now depending on speed than start to turn back into the corner so i stay sideways. I turn back in and let off the gas a bit then hit the gas hard and begin more counterstearing. You can stay sideways for a while doing this. Go find a safe place and give it a try. If you get into it and need more help get the drift bible video and watch the part where he drifts the ae86. Thats pretty much how to do it in an underpowered car.
black 1989 porsche 944 DRFT Last edited by 944drift; 03-15-2005 at 09:38 AM.. |
Rage- that is one hell of a 951 you have, Love the car, Love the video, neve knew a 951 could sound sooo pissed off, LOVE IT
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
So my friend just showed me this, and thought you guys had to see these nutballs doing their version of open road drifting
Keep me far away from these people.Check it out here.
'84 944, '05 GTO |
yo that was crazy
The Qatar guys are crazy, I've seen them do wheelies on super bikes from round about to round about in (500-700 meters) and doing well over 200 kph.
Rick 99 996C4 06 525XI 87 944S - Sold 77 924 - Sold |
looking for an S13 or FC that's in decent shape to start a real car The 944 blew up too much and was difficult to drift...
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
Ok, I don't drift my 944, nor do I play a drifter on TV. But there are some things that are incorrect in terms of car dynamics that 944drift posted. I do have a bit of track driving and autox experience under my belt, and it doesn't matter what venue to play in, basic car dynamics and techniques are the same.
So, here goes: Quote:
Hitting the brakes will cause the weight to transfer to the front of the car. Thus, there is more grip up front. This results in more of an OVERSTEERING attitude. (Oversteer occurs when there is greater slip angle at the rear of the car vs. the front of the car) Letting off the brakes and appling throttle will cause weight transfer to the front of the car. Thus, you have greater traction at the REAR of the car. This causes more of an UNDERSTEERING attitude. (Understeer occurs when there is greater slip angle at the front of the car vs. the rear of the car) -Z-man.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5 |
I've taught drifting, and do a lot of autox and hot lapping in my car, so I've seen some of the drivers out there and their techniques. 944drift is using some agressive techniques which really aren't required with the 944, but I'll try and explain what he's doing.
Now, on a 944 (NA or turbo), you can induce oversteer easily via trail braking alone, so there's no need to use shift locking. It's very hard on the LSD and tranny (driveline shock) especially if there's a high level of grip. Most drifting is done in 2nd gear, and with 1st and 2nd being the weak link on our trannys, it's not a desired way to initiate a drift. Quote:
.If he's using that technique to initiate a drift into the first corners, it's much easier to transfer weight by steering into the opposite of intended direction then hard into the direction of travel, much like rally drivers. |
rage2:
Thanks for the explanation - all I can say is drifting with a 944 is like cutting down a tree with a butter knife. It can be done, but there won't be much left after it's all done. Yikes - all this jerking, yanking, slamming - quite a different approach than the techniques I've learned for autox and track driving. Whatever floats your boat, I suppose. I will say that drifting is fun to watch, but I'd rather deal with slip angles that are less dramatic! -Z .
the technique i posted is good becuause it caters to what judges are looking for in compitition. They want it to look like you smoothly entered the corner drifting. They dont want to see you feint wiht a large sweeping motion to get the drift started. Without this technique added to you feint that is what would be needed. This technique is great if you are going to fast for a tight turn and need to slow down a bit to properly drift it. If you are approching a mild turn, then a clutch kick with a slight feint is ideal because it will keep your speed high and your car will look nice and smooth going into the drift like you arnt even trying.
There are easier ways to get sideways but most of them arnt what the judges want to see. Even if you dont compete you should aim to drift the right way. A controlled slide into and out of the corner, not just a burst of gas at the apex to kick the end out. that is not driftng. there really isnt as much jerking and slamming as it sounds in this technique z man. It is comes off very smooth when done right. It just takes a lot of practice. Go to tremek.com and check out the drifting vids and see what im talking about.
black 1989 porsche 944 DRFT |
Ok, someone help me here: what the heck is "feint?"
944drift - nothing personal, but if you check your grammar and spelling, it would be much easier to read your posts. -Z.
Location: Sometimes Sacramento, Most of the time Concord, CA
the feint is one of the many techniques used to create a drift by forcing a weight transfer of the car, causing the slide.........
lets say i was going to make a right hairpin turn......before the turn i would jerk the the car right, then left which causes the weight transfer, and then i would start drifting into my right turn, of course controlling the application of the throttle and counter steer....... think of a pendulum........
1987 944 Naturally Animalistic "If you make the same mistake twice, doesn't that make a total of three mistakes?" |
Face it, Z, some of us just won't ever be cool enough to drift.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
What is not cool is the 90% of the idiots that try and do drifts around corners at local meets.......... I know you run some drift sessions in racecity Rage........but up here we have too many idiots that think Jasper Ave is the place to throw it left/hard right and then WOW the bystanders with a half assesed attempt. I am sure you have heard of accidents/close calls from some of your locals trying out there mad skillz. The fact is we don't have the facilities for them to try this. I am not sure if the Solo2 guys would be to excited about seeing guys drifting around the course........... .......and the reality is that in the younger crowd. "Drifting is cool" it has nothing to do with developing better driving skills. (Complete generalization that applies to 90%) P.S ..............auggh.......... I can't believe the roads were clear and now there is a half a foot of snow on the ground and its still coming !!!!!!!!!! You have to love Alberta weather....
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Don't tell me that I'm ignorant to new ideas just because I don't want to drift my 944S2. You feel that drifting is the newest, latest, best form of motorsport. Kudos to you. While I find it interesting, I prefer my autox and hot lapping at the racetracks over getting my car to go sideways. Side note: most drifters do admit that their sport is more show - that drifting is NOT the fastest way around the track. Like ae1969 said above, I don't have respect for the bozos who attempt to drift on the streets, much like I have no respect for street racers. But that's a different story altogether. What's next, you're gonna call me an old fart?!? -Z.
