Can you help ID these parts
Howdy...
As some of you may know, I posted a while back about selling my 83 to a guy at work. He bit a curb, hard. I finally got to see the carnage and have pm'ed someone on this board for the parts. Damage on pass side front wheel only. -Tie rod toast -sway bar toast -What I would call an A-arm actually shaped more like an "L" in this case is ruined. Strut comes down and attaches to the wheel, hub assembly? The "hub assembly" attaches to the ________(A-arm). -Strut is bent and I have advised r/r both front. Possible wheel bearing r/r because of the impact that shoved the wheel BACK into the fender. Fender now rubs door on opening and a little body damage to fender from tire rubbing on his drive home. -New tire is ground down to steel threads and paint is gone from fender. He drove it home right after he hit the curb to avoid a tow charge. (shaking head) He is a good guy just made a bad decision and I told him I'd help him if anything went south. Thanks guys Jerry |
lower ball joint
| All times are GMT -8. The time now is 01:45 PM. |
