Question Pitch Circle Diameter of Wheel Studs
Just to confirm what I can gather from a search I did on Wheels. mlue (17/2/05) speaks about standard 944 wheels having a 5 x 130 bolt circle, and iceshark (19/2/05) a 5 x 130mm stud spacing.
I take it that is the same as what I would refer to as the Pitch Circle Diameter of the 5 wheel studs?
I can get 15" alloy wheels that are made locally here where they will machine the stud holes to the PCD I require.
What else beside offset should I be careful of when purchasing new wheels?
I am keeping to the 15" 215/60 Bridgestone Potenza SO3 tyres I have as it is too expensive to replace all 4 tyres at same time as wheels.
thanks
Old 03-29-2005, 01:09 AM
fast924S's Avatar
Send a message via AIM to fast924S
I would just make sure they are made well, I have seen some wheels crack, Also rim weights if they are heavier then it could hurt performance
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-29-2005, 03:49 PM
