Send a message via AIM to drfatz
Stock Ride Height
Anyone know what the stock ride height is for an 1985.5 NA 944? I recently changed the suspension to coilovers and am going to set the ride height back to stock, for i know it wasn;t stock before I began all of this
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 03-28-2005, 01:52 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
well here's the thing - the US stock ride height had the back end jacked up so that it would meet US bumper requirements... for balance/handling, you really want the front and rear (all four corners, actually) to be level. So getting the rear level with the front should be your priority.
Not sure what the front ride height is, though.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-28-2005, 02:59 PM
The real reason I ask if because you can't (to my knowlage at least) adjust the rear camber. So traction becomes a big issue if the ride height is to far off especially when you now have 11" wide rear tires! ;-P
1985.5 944 NA
Old 03-29-2005, 10:17 AM
Writer/Teacher
CJFusco's Avatar
isn't 11" of rubber a bit much for a 2.5 NA 944? I mean, 1 pound of unsprung weight equals about 10 pounds of sprung weight when one considers accelleration.
Old 03-29-2005, 11:11 AM
Perhaps, but I got a nice deal on these Boxter wheels so I figured why not :-p
1985.5 944 NA
Old 03-29-2005, 01:55 PM
Send a message via AIM to michaelathome Send a message via Yahoo to michaelathome
Most US models came from the factory with positive rake set to the rear... this is due to US bumper height restrictions. The top edge of the bumpers were set to: 522 +/-20mm Rear, 526 +/-20mm Front (533 +/-20mm for S2).
Old 03-29-2005, 01:59 PM
bearone2's Avatar
Question
is the measurement any different with the nose/rear valence on the 951?
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-29-2005, 02:39 PM
How about stock height from ground to center of wheel well?
1985.5 944 NA
Old 03-29-2005, 09:32 PM
