-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Need an Idle Speed Valve (http://forums.pelicanparts.com/showthread.php?t=215985)
chitown944 04-12-2005 02:19 PM
im sick and tired of the rpm going all over the place. Im quite sure its the ISV cuz if i smack it the rpms go to normal. Anyone have one for sale. Whats invovled in installing a new one.
fast924S 04-12-2005 02:28 PM
Im assuming your talking about the cold start valve? If it gets stuck open then your RPMS will rise, Anyway, I think you will need to remove the intake manifold since it is located under there. Other than that its not really hard at all.
SoCal Driver 04-12-2005 05:20 PM
You have to jumper between pin B and C on the diagnostics plug before you set your idle. Otherwise it just wanders all over the place.
chitown944 04-12-2005 10:49 PM
SoCal I tired the bypass...it simply doesn't work. I jumpered the B and C like Clarks Garage sugggests but it does diddly squat...is there another way to jumper it.
SoCal Driver 04-13-2005 07:48 AM
How did you adjust the idle after you jumpered between B and C?
Anyway, since you can hit the idle control valve you know it's under the intake. Some find it necessary to remove the intake to get to the valve. Others have reported they have R&R'd the valve with the intake on.
Once you get it off just give it a good soaking with PB Blaster then Carb cleaner. Check all of the vacuum lines before you put it back on.
SoCal Driver 04-13-2005 07:53 AM
And you might want to replace the o-ring on the idle bypass screw.
chitown944 04-13-2005 11:19 AM
After jumping the B&C terminals...I adjusted the idle using the idle screw on top of the throttle body as depicted in clarks garage. But it doesnt do much as far as helping at all cuz eventually the ****in thing goes back to 2k rpm. I'm ready to drive this thing into a wall.
WTF is the idle bypass screw...is that the same as the idle adjuster screw
SoCal Driver 04-13-2005 04:43 PM
Yeap.
Check the setting for the TPS. Which trottle body is this?
chitown944 04-13-2005 04:57 PM
um 85.5 na throttle body...well i ordered the idle speed valve should get here by friday...thanks for ur help
SoCal Driver 04-13-2005 05:06 PM
May be the DME.
