Oil level sensor wire
As I am going threw everything. I have found that the wire that goes to the oil level sensor is very weak and kinda broken were it enters the sensor plug, I have a parts car with a good sensor plug wire, Can I just cut the damaged part out and splice in the new plug end or is the wire special or sheilded??? THanx agian :D
Should be just a standard wire, You can cut and splice.
AFJuvat |
| All times are GMT -8. The time now is 07:56 PM. |
