Reverse (tranny) Problems
My car won't go into reverse. If I hold the lever into the reverse position with a ton of force it will go but it sometimes grinds. I have messed with the adjustment on the linkage and can't figure anything out. The weird thing it when I drive the car around for awhile it will start working again. Then it just randomly acts like it has no reverse. Please help.
1983 944 Copenhagen Blue
MODS: ENGINE: Firebraid 9mm plugwires. Weltmeister Throttle Cam, Dansk exhaust. lo-temp thermostat & fan switch, aluminum radiator. SUSPENSION: H&R 250lb springs, KYB GR-2 struts(front) Bilstien Shocks(rear), Racing Dynamics strut bar, APPEARANCE: 15" Phone Dial wheels, a-pillar w/ VDO H2O and volts gauges.
1987 944-S Montego Black
-needs your help
Old 05-15-2005, 07:13 PM
Autobahn Garage
How many miles on the car? Have you whipped on it? I'll P.M. you my phone number I'm in ohio and run a shop. Call me I may be able to help you out
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 05-16-2005, 05:05 PM
DP944's Avatar
hey nathan you should post some picks of your car....sounds like it has a lot of mods
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche
Old 05-16-2005, 06:52 PM
appx 100K miles on it and the car gets babied. Never even seen an autox.
-needs your help
Old 05-17-2005, 04:15 PM
I shall do that sir.
-needs your help
Old 05-17-2005, 04:16 PM
Autobahn Garage
nathan944, I'll P.M. you my # Give me a call if you wish
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 05-17-2005, 05:44 PM
