capetown944's Avatar
Porsche Crest Gear shudder
Hi.
I have a 944 s2 cab. When I gear down from 3rd to 2nd the gearlever shudders quite violently. This does not happen when gearing down through other gears nor does it happen on gearing up. I have had the gearbox mounting checked and that seems fine. Any ideas or similar problems experienced?
Thanks.
Old 05-13-2005, 03:24 AM
rudidelange's Avatar
Nice to see a another car from South Africa. I noticed that you number plate is smudged.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 05-13-2005, 06:29 AM
SoCal Driver's Avatar
Check the linkage over the top of the transmssion and the couplers to the shafts sticking out of the transmission. Could have it trying to go into two gears at the same time.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-13-2005, 02:04 PM
Needs a clutch, probably the beginning of the end of the rubber hub.
Usually, if you get a good tech to drive it, they will get this problem in most of the gears.
Normal sign is the vibration seems to sound or feel like the exhaust hitting the body.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 05-14-2005, 07:01 AM
Thought that by the time the S2 was produced Porsche used spring center clutch plates as standard?
Old 05-14-2005, 10:25 AM
depends, if original or not-that-long-ago replacement, it could well be rubber. I know we did one a few years ago that was.
Old 05-14-2005, 11:03 AM
meister member
speedracing944's Avatar
Do some rev matching down shifts and the shudder will disappear.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 05-14-2005, 11:06 AM
marko's Avatar
Yes Britwrench, you did my S2 with a rubber center some years back, it lasted ALOOOOT longer than the original. I had mine done again last year and it was replaced with a spring center. After that, I had the exact same problem, shudder only when down shifting from 3rd to 2nd, all other gears ok. It has lessened over time, but it is still slightly there.
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 05-14-2005, 09:35 PM
tifosiman's Avatar
Ding Ding Ding! We have a winner!
1985.5 944 Club Sport
My P-caronline Profile
"A good time to keep your mouth shut is when you're in deep water. "--
Sidney Goff
Old 05-15-2005, 03:28 AM
As I understand it, they were rubber-centered all the way up through '91.
Matt
'90 Porsche 944S2 Cabrio
Baltic Blue Metallic/Linen
LSD
2002 Yamaha FZ1
Old 05-15-2005, 06:38 PM
Thanks, guys. I'll start with rev-matching downshifts and then check the rubber hub and linkages and let you know what works.
944 S2 cab
Old 05-16-2005, 12:34 AM
