Quick help needed
Does the windshield little rubber trim glued in place or just stuck in there or what? I was driving down the highway and car started making a loud thumping noise so i pulled over immediately and found out it was the rubber gasket around the windshield so i pulled it off and drove back home. Do i need a new one or just glue this one back in place? Thanks.
Glued. Black silicone. Car window type.
Uhmmm both of my 86's the rubber gasket is just pushed in. If the underlying frame is too loose then you will probably have to glue it.
Thanks ya'll, man i love this place.:) ;)
Use urethane. Not silicone.
| All times are GMT -8. The time now is 04:44 AM. |
