-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Clutch Problem (http://forums.pelicanparts.com/showthread.php?t=222824)
gwaveguy 05-23-2005 08:36 AM
Clutch Problem
I have a clutch that is giving me trouble. I replaced the slave and masters a couple months ago and it has been working fine. A couple days ago the clutch became completely ineffective. I pressed down the pedal and it stuck to the floor, upon lifting it, the clutch pedal got jammed to where no level of pressure will move it back down but the clutch is not engaged (stuck in neutral). I haven't been able to get down and see what's going on yet, but any thoughts as to if this looks like a problem in the pedal assembly or something much deeper?
rb101 05-23-2005 09:14 AM
bleed it, you have a air pocket
