I am replacing my control arm this weekend most likely and I was just wondering....when I remove it will the strut be able to move....like have free play. Right now the strut is at an incorrect angle because the control arm is bent. Im just hoping that the strut will go back to the right angle once the control arm is bolted in. Any ideas?
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche |
Re: Just a question...?
Jack 86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi 83 Porsche 944 - Still under re-construction. 08 Suzuki Boulevard M109R LE 02 Nissan Altima SE3.5 |
How did you bend the control arm?
Most times when an impact is that great it bends the strut housing and the spindle. You can see the buckle in the strut right at the top of the spindle attachment where it necks down to hold the shock cartidge.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Burn the fire.
Front or rear? I'm assuming front... Does the 944 have spindles on the wheels up front?
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
