Send a message via AIM to drfatz
gauge cluster acting up
The car runs fine, but the speedo reads zero for a bit after you come to a stop and start moving again untill u hit a bump or u hit the dash then it pops up. Also the fuel gauge reads consistently 1/4 tank lower then actual and the temp gauge fluctuates alot. Im thinking its bad grounds or bad connections but I was wondering what you guys thought.
1985.5 944 NA
-Racing Headers, Cat-less Borla exhaust, New racing Cam, Turbo valve springs, multi angle valve job, big bore throttle body, Eprom, blue printed injectors, throttle response cam,
-Just installed: M030 Suspension with turbo A-arms and hubs. Big Reds with rotors and stainless lines. Turbo sway bars front and rear. Boxter wheels, turbo mater cylinder, and MOMO steering wheel and shift knob.
Just Finished: Clutch, flywheel and transmission...and TONS more!
Old 06-23-2005, 11:46 AM
Non Compos Mentis
Probably bad grounds.
Old 06-23-2005, 12:59 PM
