Location: Sometimes Sacramento, Most of the time Concord, CA
Should I?
hey everyone, as you know, i blew my transmission and i am definitely going to get a used one......i have an 87 NA and i've decided to try to get an S transmission, because the r&p gears are stronger and the gearing will work for my car.....
so i came along this, what do you guys think?
1987 944 Naturally Animalistic "If you make the same mistake twice, doesn't that make a total of three mistakes?" |
Check around locally for a trans. Easier to return a bad one.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
If you can afford it.. I think the S2 has an even stronger R&P.. not sure if the S actually does.
1985.5 944 NA |
IIRC, the S has the 951 R&P, so it would be fine. The gears in the S2 are too tall for an NA.
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos |
ok, sounds good, now to hope to find an S tranny locally.....
