Warwood's Avatar
Cool Twisted 944S
Good, I have your attention. A good friend of mine called me a few months ago to tell me some guy wanted to do a V8 Cheby swap into his 944S. Well, I have heard this kind of plan before and had made them myself, but never acted on them. So I was pleased when I had a chance to see one of these being converted myself.
To disguise my intrigue over this project I say, "Kw-el, but why does he want to dump the 16V engine?" Ok so to make a long story short, it turns out that this particular 944 16V has had a problem eating cams and destroying heads. So the owner (we will refer to him as Mr. Smith) decided that it was time to stop messing around. So Mr. Smith bought an LT1 Corvette engine and rebuilt it to LT4 specs.
Specification LT4
Block, construction Cast Iron
Bore, inches 4.00
Compression ratio 10.8:1
Connecting Rods Powdered metal
Crankshaft Cast iron with undercut and rolled fillets
Cylinder Heads Cast Aluminum, 2 valves/cylinder
Displacement 350ci (5733cc)
Fuel system Fuel Injection, Electronic sequential port
Horsepower, factory rating 330 @ 5800 RPM
Main Bearings 4-bolt centers, 2-bolt ends
Pistons Eutectic aluminum/silicon alloy
Redline, factory rating 6300 RPM
Rocker Arms Conventional, forged aluminum, 1.6:1 ratio
Stroke, inches 3.48
Timing Chain Roller chain, steel sprockets
Torque, factory rating 340 @ 4500 RPM
Torsional Damper Dual mass
Valve Diameter, inches 2.00 intake, 1.55 exhaust
Valve Duration 282 intake, 277 exhaust
Valve Lift, degrees .476 intake, .479 exhaust
Valve Overlap, degrees 46
(I have been told that the cam shaft in this engine is larger than stock.)
Valve Springs Oval section, higher closing force
The expected output is reported to be about 415Hp.
I when I saw the car for the first time, it was preped and ready to start.
Putting the engine into the car, wasn't as easy as the kit maker would like you to think. The first fitting left the engine sitting to high and interfered with closing the hood. But after readjusting the mounts the engine dropped down and now the hood closes.
The clutch is uses a well engineered slave cylinder, and came with a steel braded line.
The alternater bracket had to be cut and welded, making it shorter required clear the hood. But this meant the alternater is very close to the power sterring pump. In this case it actually rubs.
Where the cross member is well made we had a problem; for some reason it didn't fit very well on this '87 944S. As you can see the bolt holes had to reamed out to fit frame.
The power sterring rack pressure inlet line had to modified to changed to accept the SAE line from the GM power sterring pump.
As you are wondering about exhaust I am sure you will agree that the stock single 2 1/4 inch pipe will not flow enough exhaust to make 415 Hp. But I am told that the new custom exhaust will take care of that!
That's all for now, as I get more pictures and info I will keep you informed.
Have a good one,
Revis Rose
'84 944 NSRC
Old 07-08-2005, 10:49 AM
ae1969's Avatar
Send a message via ICQ to ae1969
The beauty of cubic inches.
Definitely keep us posted with some pics.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 07-08-2005, 11:02 AM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
makes me sad to see the a 944S lose its heritage, but it also makes me happy to see what you can do with a little time an money, that thing is going to be a monster.
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 07-08-2005, 11:17 AM
Burn the fire.
Brando's Avatar
Will it pass smog?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-08-2005, 11:54 AM
Warwood's Avatar
Originally posted by Brando
Will it pass smog?
I don't why not, it may require a refferee to decide bless it. But there is no reason it shouldn't pass the sniff test if my friend and Mr. Smith install cats.
Revis Rose
'84 944 NSRC
Old 07-08-2005, 01:21 PM
meister member
speedracing944's Avatar
What is funny is I am also named Mr. Smith and I have a 87 944S that has motor issues. I laughed when I read this post.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 07-09-2005, 09:07 AM
Very interesting swap...
Keep us posted...
I currently have a 89 Nissan 240 SX with a Chevy 350 V8 swap...Not pushing those kinda HP numbers, but fun all the same...
I am looking at a 87 944S...Bad idea?
I have heard all the issues...and it needs the full belt service too...So, I am unsure if I want to pay a decent price AND have to pay for the full service too...
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 07-09-2005, 09:36 AM
use the belt issue to give you lee-way on lowering the price
Old 07-09-2005, 05:06 PM
Warwood's Avatar
This particual 944S's engine failed due to cam chain failure. Which took out the cam shafts and the head. Bad news.
The 928S4 and 944S, S2 all had problems with their timing chains.
Revis Rose
'84 944 NSRC
Old 07-09-2005, 08:34 PM
Warwood's Avatar
oh yeah by timing chains I meant cam chains
Revis Rose
'84 944 NSRC
Yes, thats what I was thinking Philly's...
89 Porsche 944
Old 07-11-2005, 07:53 AM
let me know if you want to sell the 944S block, I understand the head is trash, but did the block and lower end survive.
Old 07-11-2005, 12:22 PM
