Wiring up the fuel pump...
Well I have tracked down the wiring problem and from the replies to the post Im not going to wire it up... But I do have a problem the car will not idle for more than 10 minutes but then can be immediatley restarted. I have replaced both the switch and relay... so what could it be.
you prolly can but you would have to use a relay to swith a hot from the battery using the signal from the dme. and you should use maybe a 10 awg wire to minimize voltage drop and keep the pump going strong while your at it.
You will burn out your fuel pump that way.
Are you sure you are having a wiring problem? The Fuel pump relay controls the computer (DME) and the fuel pump. If there is a problem some where in wither of those circuits, the car will not start. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
