Getting harder to shift...
As of late, shifting in the 944 has become more difficult. This applies to all gears, but especially 2nd.
Do I just need to change my tranny fluid? |
Change it to Swepco synthetic tranny oil -- you should see a notable difference, especially if your tranny's in good shape.
-Z. |
oil swap easy to do? time consuming?
You've never done tranny oil, cjf? I'm shocked!
17mm allen socket, don't overtorque. I think 17 ft lbs. |
Just make sure you undo the bolt on top of the tranny first, to make sure you can add the new oil after you've drained the old one! :D
-Z. |
is this the Swepco 201?
... and how much should I order? Gallon? |
A little over 3 quarts, iirc.
edit. just checked, it should take 2 3/4 quarts. |
| All times are GMT -8. The time now is 04:54 AM. |
