| pearljaman31 |
08-01-2005 09:06 AM |
Rough idle and stalling in neutral
I have an 83' 944 manual transmission. My car idled rough in neutral from 900 to 200 back and forth until it would stall out and die. One day i tightened the throttle cable by twisting the metal hexagon edged piece connected to the rubber hose which incased the cable. Problem solved. But suddenly, 2 months later, im getting the same problem again. Intermitently its idleing rough in neutral. Any answers on how to fix this? I tried tightening the cable again but that didnt help.
Ive replaced the spark plugs, transaxle fluid, and oil filter recently.
Also, when i was in line at the drive through everything was fine...but i seemed to be idling around 1000 instead of 900 and i just tapped the dash with my finger, i heard a quiet noise like a fan turning on and the neutral rough idle started right up. Maybe thats just some weird coincidence though.
