How can I stop a dash crack?
I have a 944 with a perfect dash, until now.
A hairline crack has started at one of the vents by the windshield. It started towards the interior of the car and is less than 1/4" wide. Any suggestions? Super glue? Anything? |
Keep the car from getting too hot inside? I'm sure significant expansion and contraction play a part in dash cracking.
Don't use Super Glue. It doesn't play well with the foam backing or the vinyl skin. I am not sure what would work well, though.
Still looking for the right deal on another P-car 1968 BMW 1600 2 liter 1956 Ford F250 1955 BMW R69 1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...) |
About the only thing that you can do is ask Superman to circle the globe counterclockwise, setting up a time warp so that all time stands still.
Short of that, get a dash cap or a dash carpet. The crack will still propagate, but you won't be able to see it. gb
Good luck, George Beuselinck |
No!!!!
Chia Dash is a ripoff! I used it once, a few weeks before putting my car away for the winter. Don't chia-fy the dash unless you plan on bi-monthly pruning.
''87 944na 85k C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946 '94 Oldsmobile 88 Royale (winter beater) Its not what you drive, its what drives you. |
wow...once again this forum has saved me from certain disaster
my FR Wilks do it yourself Chia Dash Cover is going on eBay !
Tom Early '85 944 |
actually I have used and do like some of the SEM product line
but has anyone used: http://www.sem.ws/product.php?product_id=123 or http://www.sem.ws/tip.php?tip_id=4 with any luck?
Tom Early '85 944 |
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
Years ago I bought a dash cap from Accuform. After a few years it develpoed a slight warp. I asked Accuform how to repair this and they sent me a full replacement unit. Any way you figure it, the dash cap looks a lot better than a cracked dashboard. Just follow the instructions to the letter. Very little adhesive (supplied) is used, around the edges to give the plastic room to expand and contract.
Bob S. former owner of a 1984 silver 944 |
Dog-faced pony soldier
I have yet to find a dash cap that doesn't sound cheap and tinny/hollow when you tap on it though. Maybe some expanda-foam stuff under it would help?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
You mean the original doesn't look and sound cheap?
ha ha, you got that one right on, bob !!
1984 944 na. FR. WILK power prom/dual chip. 2005 buick. daily beater 2002 grand am--better halfs ride. olds 98 royal brougham--gone, but not forgotten. |
I always wonder what happened to the steel dashboard that had a removable padded cover on it. Seems as if it would add lateral stiffness to the body where it is needed the most. Most older cars that I have worked on were built that way, not out of compressed cardboard with a leatherette cover a few microns thick.
I have also noticed that the "grain" on most 944 interior parts is different part to part, resulting in a strange look.
Back from Beyond
To do a dash cover right, pull the dash so you can get good pressure evenly on the cover, Otherwise it'll always look like an add-on. Mine does. My wife took out her dash before gluing the cover on and it looks a thousand times better than mine.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
