Composite Shop Owner, DJ
Car back from service
Just got my car back this evening from the Porsche Service Department. Had the belts done (put on 30,000 in the last year and a half). All the tensioners and rollers were done then and I only needed one tensioner replaced this time.
Also did the A/C R134a retrofit and she blows coooooold now!!! ![]() The only bad news was the bill.
'86 944, 5 Speed (Daily Driver) |
at the billotherwise, thanks for doing the service and preventing us from having to suffer through "is there a possibility that i didnt bend my valves" thread
1987 944 - Wrecked turned parts car 1986 944 - Awesome Auto |
how much, I need to do this an am looking for
1985.5 na 1986 951 nice; Mine 1986 951 nicer. Hers These things are addicting.... |
quotes
Here are all the numbers and descriptions of what I needed.
Timing Section 944-105-157-04 Timing Belt 944-102-219-04 Poly-Rip Belt (Balance Shaft Belt) 944-105-027-04 Timing Belt Gear 999-084-092-02 Locking Nut (x2) 944-602-901-01 Distributor Rotor (Mine was cracked/broken) Labor: $427.50 A/C Section Already had new compressor and dryer. (from ebay) 928-573-965-01 A/C Pressure Valve $49.21 928-573-965-00 Low Pressure A/C Valve $49.21 964-701-141-02 Decal-A/C Retrofit (2 required) $1.87 ea 944-126-935-01 Rubber O-Ring (x4) $8.72 ea 999-707-251-40 Rubber O-Ring (x1) $1.31 ea 999-707-434-41 O-Ring (x1) $1.37 999-707-247-40 Rubber O-Ring (x2) $1.08 ea 000-043-205-84 Felt Stripe (x1) $1.35 ea Labor: $665.00 Grand total after a few other items such as shipping and misc. parts came to $1640.98
I'm smart enough to know that I would bend them.
