LOUD noise
I have an '89 951 and just yesterday it started emitting a very loud, steady, high pitched noise from under the hood.
It does not fluctuate in pitch at all and starts as soon as I start the engine and stays until I cut it off. Any opinions would be much appreciated.
Thx..
Wyld
*edit-- the noise seems to be coming from the passenger side maybe a foot or so forward from the windsheild.
Old 08-23-2005, 06:46 PM
livewirevoodoo's Avatar
A whining sound? belts?
Where under the hood?
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 08-23-2005, 06:48 PM
I think it is too high pitched for a belt it sounds kinda like the whirring alternator sound that you hear through your speakers if you hook up your radio wrong..but MUCH louder.
I am not familiar enough with this engine yet to give a pinpoint location But I know if you are looking down at the engine it seems like it is coming from the passenger side/middle and about a foot in from the windshield.
Old 08-23-2005, 06:58 PM
Hmm... a foot in from the windshield on my non turbo places the noise smack on the engine.
too high pitched for a belt can still be a roller/pulley under the timing belt cover (front engine, by water pump, under black plastic cover).
a stethiscope might help you track down the source.
''87 944na 85k
Old 08-23-2005, 07:04 PM
I just had the balance belt and timing belt replaced on Saturday. The mechanic told me the rollers and such were in good shape. Here is another poor attempt at showing you the location:
Old 08-23-2005, 07:09 PM
AFJuvat's Avatar
Ok, need some more info. What kind of noise, a whine, grinding, a whirring noise?
Take a long screwdriver and touch various (non-moving) parts and see if you can localize it. Bolts, nuts, and studs make excellent sound transmitters.
research and report back
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-23-2005, 08:02 PM
pokey's Avatar
Send a message via AIM to pokey
Cam bearing?
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 08-23-2005, 08:29 PM
AFJuvat's Avatar
That is what I was kind of thinking.
AFJ
Old 08-23-2005, 08:59 PM
Back from Beyond
Here's a thought. Check your starter. Sounds like it may not be disengaging properly. I know this sounds nuts, but with my car, last time I boosted another car I got a horrid whine exactly like what you're describing. Won't do that again. As soon as I disengaged the cables the noise stopped. I think it was the starter.
Check your electrics system too. If voltage to starter is squiffy then that could cause problems too.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-24-2005, 08:10 AM
Thx for the help guys. I will have to troubleshoot it another day seeing as how when I started it up this A.M. no noise was present. I tightened down everything in sight and I have my fingers crossed.
--Wyld
Old 08-24-2005, 10:17 AM
winter-hater club member
nynor's Avatar
that is sounding like the starter. intermittent disengagement problem with the solenoid.
"COOL PRIUS!" - Nobody Ever
Old 08-24-2005, 01:11 PM
The sound is definitely back. What should I do when I check the starter? How do I disengage the cables? Lastly, where the hell is the starter?
--- FNG
Old 08-24-2005, 08:42 PM
Your arrow seems to be pointing at the fuel rail....
Injector? I have seen them do some funny things...
You really need some basic manuals on the car. The starter is (obviously) under the car, on the passenger side of the rear of the engine. Can't miss it. As strange as this sounds, please remove all cables from the battery before removing the starter. There was one poster a while back that didn't want to do that because he had just set all his presets on his new sound system!! Any good shop should be able to check the starter for you. Not a really bad job.
Bob S. former owner of a 1984 silver 944
Old 08-24-2005, 11:23 PM
You know the location of the sound is EXACTLY where you say the starter is. I will explore that and report back tonight.
Thank you all for your help it is greatly appreciated.
--Wyld
Old 08-25-2005, 04:29 AM
*Update:
It turned out to be the heater control valve diaphragm that is causing the hellacious noise. My picture was a little off.
'89 951
Old 08-28-2005, 06:00 PM
