-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   968 6 speed into s2...speedo? (http://forums.pelicanparts.com/showthread.php?t=238324)
avwguy 08-29-2005 06:55 AM
i understand that the 968 used the abs to drive the speedo, and after reading and researching a few items, I am still wondering. I have abs in my s2(as all do) so i am thinking that this should just go straight in and not have any isue with the speedo. I read people saying that the signal is from the abs unit on the 968, but they are the same part s2 and 968.(according to pet) has anyone done a swap into a abs car?
AznDrgn 08-29-2005 07:54 AM
The 968 gets signal from the ABS but the S2 gets its signal from the tranny. I'm not 100% how the 968 interprets the signal but you'd probably have to use a 968 ABS module and then rewire your dash to accept signal from the ABS unit rather than the tranny sender.
avwguy 08-29-2005 10:31 AM
Re: 968 6 speed into s2...speedo?
the abs module is the same unit on both according to the fiche(i also double checked my car and it matchs the 968 part).
carsontc 08-29-2005 05:51 PM
so are you thinking that the speedo sender in the S2 transaxle is not used? what happens when you unplug the connector?;)
I'm thinking the signal from a front hub goes into the 968 DME...processed to look the same as the 944 cars and sent to the speedometer.
avwguy 08-29-2005 06:15 PM
here ie the other rub, s2 and 9687's can and often use the same ecm..i have a 968 one in my car now...? just doesn't add up. anyone have 968 wiring diagrams?
carsontc 08-30-2005 12:19 PM
I did notice the S2 & 968 DME's had same p/n...do you know if the program chip in each the same too?
on the 968 DME, pin 6 (rotational speed) goes to the 14 pin connector (near DME) pin 2 green/black
while the 944S2 DME pin 6 (no name) goes to the 14 pin connector (near DME) pin 2 (green/black??)
on the 968 DME pin 2 (speedometer signal) goes to the 14 pin connector (near DME) pin 6 green/red
while the 944S2 has a DME pin 2 has no wire to the 14 pin connector (near DME) pin 6
hmmmm...need to study these prints some more
do you have a 968 transaxle ready to go?
avwguy 08-30-2005 05:19 PM
i am in the process of buying one now, will be selling the 5spd from mine(has lsd) to recoupe the $
