Porsche Crest dome light
Hello, I am having trouble with my dome light. It doesnt go on when I open the doors but it works when switched on. I have replaced the accuaters in the door but still no luck. Thank You!!
1984 944
Old 08-31-2005, 12:34 PM
Don 944 LA's Avatar
check that the plastic that the switch arm rides against isn't melted.
Mine had that same problem and I had to tweak it alittle bit to get it to work. Now it comes on when the doors open, but it's flakey when I switch it on manually.
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 08-31-2005, 01:45 PM
Hi, I replaced the dome light with a new one but still have the same problem. Any suggestions?
Old 09-11-2005, 03:47 PM
Granite 944's Avatar
Common problem is the right rear hatch shock grounding point. Do a search here on interior lights, and I'll bet ya find more than ya wanted to know.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 09-11-2005, 04:07 PM
Rear hatch light works fine, just the front light won't come on when door is open.
Old 09-14-2005, 01:49 PM
Is the front overhead light switch in the correct position for it to come on?
Old 09-14-2005, 07:06 PM
Front switch is in correct position.
Old 09-16-2005, 02:56 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Well ensure that the grounding wire from the door actually makes it all the way to the light otherwise it will not trigger the light.
Just check continuity.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-16-2005, 03:32 PM
yeah......what alex said above. Take door switch off jamb again, and check it. It must create a ground path for light to work when door is opened. Maybe there is a bad connection to the back of switch, or it disconnected from switch on the last install?
Old 09-16-2005, 09:00 PM
